v2.2.1
Using Caddy Alpine.
Caddy is run in a pod, inside Kubernetes, inside Minikube.
Our Caddy pod Dockerfile:
ARG CADDY_VERSION=2.2.1
FROM caddy:${CADDY_VERSION}-builder-alpine AS builder
ARG ROUTE53_VERSION=1.0.2
RUN xcaddy build \
--with github.com/caddy-dns/route53@v${ROUTE53_VERSION}
FROM caddy:${CADDY_VERSION}-alpine
ENV XDG_DATA_HOME=/data \
XDG_CONFIG_HOME=/config
COPY root /
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
svc: static
type: deployment
namespace: 'development'
spec:
replicas: 1
selector:
matchLabels:
svc: static
strategy:
rollingUpdate: null
type: Recreate
template:
metadata:
labels:
svc: static
spec:
containers:
- image: 'local/static:latest'
- containerPort: 80
- containerPort: 443
volumeMounts:
- mountPath: '/data/caddy'
- mountPath: '/config/caddy'
restartPolicy: Always
- name: static-storage
persistentVolumeClaim:
claimName: 'development-static-volume-claim'
(tls-majority) {
tls {$ACME_CA_EMAIL} {
dns route53
header Strict-Transport-Security max-age=31536000;
(tls-alpha) {
import tls-majority
(tls-beta) {
import tls-majority
(tls-production) {
import tls-majority
(tls-local) {
issuer zerossl {$ZERO_SSL_API_KEY} {
dns route53
(default) {
log
import tls-{$TARGET_ENV}
Content-Security-Policy "frame-ancestors 'none'"
X-Frame-Options "DENY"
X-XSS-Protection "0"
https://{$BASE_DOMAIN} {
import default
root * /www
@exceptProxy not path /css/* /fonts/* /images/* /js/* /favicon.ico /robots.txt /version.json
reverse_proxy @exceptProxy http://app:{$APP_SERVICE_PORT_HTTP}
# For the Kubernetes liveness probe
respond /_status/ping 200
Caddy seemed to get itself into a bind at some point with:
static-79d9d8fb99-x2lmr static {"level":"info","ts":1606267303.5151153,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"my.domain","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
static-79d9d8fb99-x2lmr static {"level":"info","ts":1606267378.6840162,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme.zerossl.com/v2/DV90/order/0a7qMB_jt0fNhttgAdz2YA"}
static-79d9d8fb99-x2lmr static {"level":"warn","ts":1606267411.2951508,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme.zerossl.com/v2/DV90/order/0a7qMB_jt0fNhttgAdz2YA","error":"performing request: Post \"https://acme.zerossl.com/v2/DV90/order/0a7qMB_jt0fNhttgAdz2YA\": http2: timeout awaiting response headers"}
static-79d9d8fb99-x2lmr static {"level":"error","ts":1606267415.1428266,"logger":"tls.obtain","msg":"will retry","error":"[my.domain] Obtain: [my.domain] finalizing order https://acme.zerossl.com/v2/DV90/order/0a7qMB_jt0fNhttgAdz2YA: polling order status: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":116.224921962,"max_duration":2592000}
static-79d9d8fb99-x2lmr static {"level":"error","ts":1606267476.4744296,"logger":"tls.obtain","msg":"will retry","error":"[my.domain] Obtain: [my.domain] creating new order: fetching new nonce from server: HTTP 504: (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":177.556524306,"max_duration":2592000}
It couldn’t get past fetching new nonce from server
After clearing out the config directory, Caddy started again and it worked. Caddy acquired the certs and is now serving everything correctly, but I did receive the following error:
{"level":"warn","ts":1606268308.7926667,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [my.domain]: parsing OCSP response: ocsp: error from server: unauthorized"}
I’d just like to point out that this was using a setup that was previously working with Let’s Encrypt. I simply switched to the new code without clearing any directories or anything.
