Issues with PHP overrriding file browse directive
docker
docker
http://486net.tk, http://www.486net.tk { #, http://192.168.0.101 {
		root * /home/486net/www
		templates
		php_fastcgi unix//run/php-fpm/php-fpm.sock
		file_server / {
			hide   .git .gitignore .gitmodules
			index  index.htm index.html index.md
			browse /home/486net/www/assets/file-template.htm
		try_files {path} {path}/index.html index.html index.htm
this is index.php
https://hastebin.com/uzosobebeh.php-template
When i go to a page such as http://486net.tk/FolderTest/ it only displays what i would see if i was on http://486net.tk/
What i am supposed to be seeing
What i am NOT supposed to see
the only difference between these two screenshots, is in the first one, php_fastcgi is disabled (commented)
and in the second one, it is enabled (uncommented)
LItterally nothing
I have tried a try_files to directly show index.htm, index.html, and even index.txt and nothing has worked,
Somewhat fixed by adding a request matcher like so
@phpcheck path *.php
php_fastcgi @phpcheck unix//run/php-fpm/php-fpm.sock
HOWEVER, index.php files do not work, and display plaintext of the php file
The problem is you set a / matcher for your file_server directive, making it only match for requests to exactly /.
Newly updated caddyfile after tweaking it till something worked
		templates
		file_server * {
			root /home/486net/www
			index  index.htm index.html index.md index.php
		rewrite / /index.php ## How i have the main index.php working at the moment
I doubt you need that @phpcheck matcher.
I think all you need is this:
		templates
		file_server {
