Issues with internal domain, Bind9 and Caddy TLS for the internal domain
I’m trying to setup internal DNS with fully working TLS for those domains.
In one of VMs on my network, I’ve set up bind9 which is zone for specific subdomain of my network: int.example.com.
Domain example.com itself is managed on Cloudflare, but I’d like int.example.com and all subdomains of it to be fully in internal network, with no exposure to outside world.
int.example.com is not present in Cloudflare in any way (as my public IP is not viable to be used there)
Current DNS chain in internal network is:
Client → Bind9>PiHole>Cloudflare
Exact issue I’m having is that ZeroSSL calls are failing in logs.
As I understand, such setup should still be somewhat supported? Will be glad for any responses, thank you in advance :slight_smile:
    "level": "error",
    "ts": 1704837424.4721053,
    "logger": "tls.issuance.acme.acme_client",
    "msg": "cleaning up solver",
    "identifier": "test.int.example.com",
    "challenge_type": "dns-01",
    "error": "no memory of presenting a DNS record for \"_acme-challenge.test.int.example.com\" (usually OK if presenting also failed)"
    "level": "error",
    "ts": 1704837424.6758957,
    "logger": "tls.obtain",
    "msg": "could not get certificate from issuer",
    "issuer": "acme-v02.api.letsencrypt.org-directory",
    "error": "[test.int.example.com] solving challenges: presenting for challenge: adding temporary record for zone \"int.example.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme-v02.api.letsencrypt.org/acme/order/x/x) (ca=https://acme-v02.api.letsencrypt.org/directory)"
    "level": "info",
    "ts": 1704837425.7460938,
    "logger": "tls.issuance.zerossl",
    "msg": "generated EAB credentials",
    "key_id": ""
    "level": "info",
    "ts": 1704837426.3400786,
    "msg": "waiting on internal rate limiter",
    "identifiers": [
    "ca": "https://acme.zerossl.com/v2/DV90",
    "account": "me@example.com"
    "level": "info",
    "ts": 1704837426.3401396,
    "msg": "done waiting on internal rate limiter",
    "identifiers": [
    "level": "info",
    "ts": 1704837426.844525,
    "logger": "tls.issuance.zerossl.acme_client",
    "msg": "trying to solve challenge",
    "level": "error",
    "ts": 1704837427.573195,
    "level": "error",
    "ts": 1704837427.777359,
    "issuer": "acme.zerossl.com-v2-DV90",
    "error": "[test.int.example.com] solving challenges: presenting for challenge: adding temporary record for zone \"int.example.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/x) (ca=https://acme.zerossl.com/v2/DV90)"
    "level": "error",
    "ts": 1704837427.7773986,
    "msg": "will retry",
    "error": "[test.int.example.com] Obtain: [test.int.example.com] solving challenges: presenting for challenge: adding temporary record for zone \"int.example.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/x) (ca=https://acme.zerossl.com/v2/DV90)",
    "attempt": 1,
    "retrying_in": 60,
    "elapsed": 35.52883398,
    "max_duration": 2592000
Caddy version: 2.7.6
with Caddy-Docker-Proxy: 2.8.10
and @latest caddy-dns for Cloudflare
VM in proxmox, running Docker with built docker image based on docs.
docker compose up -d
# Container itself is using
caddy docker-proxy
    container_name: caddy-proxy
    build:
      context: .
      dockerfile: Dockerfile
      args:
        CADDY_VERSION: 2.7.6
      - 80:80/tcp
      - 80:80/udp
      - 443:443/tcp
      - 443:443/udp
      - 127.0.0.1:2019:2019
      - ACME_AGREE=true
      - CADDY_INGRESS_NETWORKS=proxy-net
      - CADDY_DOCKER_CADDYFILE_PATH=/etc/caddy/Caddyfile
      - CLOUDFLARE_EMAIL=me@example.com
      - CLOUDFLARE_API_TOKEN #
      proxy-net:
        ipv4_address: 172.20.0.2
    deploy:
      resources:
        limits:
          cpus: '1'
          memory: '256M'
        reservations:
          cpus: '0.2'
          memory: '128M'
      - "/var/run/docker.sock:/var/run/docker.sock"
      - "./caddy/data:/data"
      - "./browse.html:/tmp/browse.html"
      - "./files:/mnt"
    restart:
      unless-stopped
  proxy-net:
    driver: bridge
    ipam:
      driver: default
      config:
          subnet: 172.20.0.0/24
          gateway: 172.20.0.1
Dockerfile
ARG CADDY_VERSION
FROM caddy:${CADDY_VERSION}-builder AS builder
RUN xcaddy build \
    --with github.com/lucaslorentz/caddy-docker-proxy/v2@v2.8.10 \
    --with github.com/caddy-dns/cloudflare@latest
FROM caddy:${CADDY_VERSION}-alpine
CMD ["caddy", "docker-proxy"]
        admin 0.0.0.0:2019
        email me@example.com
(common) {
        header /* {
                -Server
(cert) {
        tls me@example.com {
                resolvers 10.64.0.144 1.1.1.1
test.int.example.com {
        import cert
        root * /mnt/test
        file_server {
                browse /tmp/browse.html
This looks like a Cloudflare authentication error. Are you sure your Cloudflare API token is properly set? Did you follow the instructions in the Cloudflare plugin’s README for setting up your token?
You can remove this, it was only relevant for Caddy v1 and earlier.
Caddy doesn’t use UDP for port 80, only for port 443 (HTTP/3 is TLS-only)
I did, though my main domain and it’s zone is example.com in log’s case, not int.example.com - maybe it’s causing issue?
I’ve created token with Zone-Zone-Read + Zone-DNS-Edit permissions, if I recall from documentation that’s what’s required.
After some tinkering with restarting Caddy and my internal DNS; also I’ve replaced token - then it worked for the test.int.kamisoi.pl, but next domains had issue registering.
Then I’ve changed Caddyfile a bit, and seems like removing resolvers line fixed issue on my end.
So it’s working now? This is resolved?
If not, I’m not clear what the problem is. Please share logs, etc.
