The native telemetry does not work for me:
And caddy-prometheus
, which I planned to use with Telegraf,does not work
That doesn’t look like a bug in the prometheus middleware: can you verify that files in vhosts/*
are being loaded as you expect? (Try inlining the contents.) Right now your Caddyfile is malformed.
Hello Matt,
Looks like I forgot how to read…
In your
Caddyfile
:prometheus
For each virtual host that you want to see metrics for.
That last line solved my problem.
I am affected by the websocket+panic bug though: Using this plugin with websockets causes a panic · Issue #43 · miekg/caddy-prometheus · GitHub. I have websites that rely on websockets and the plugin break them.
It seems there is currently no way for me to get metrics from caddy
