Issue with cloudflare module and SSL verification
I am unable to use cloudflare module DNS to verify SSL certificates
Note: The only way I am able to get ssl dockers working is if I use the directive tls_insecure_skip_verify which is what I am trying to avoid. Which in my case is the subdomains cloud (nextcloud) & sso (authentik)
Logs made the post too long so I used pastebin: Caddy Docker Logs
v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
Docker
sudo docker run -d --rm -it \
  --name caddy \
  -p 80:80 \
  -p 443:443 \
  -v caddy_data:/data \
  -v caddy_config:/config \
  -v /home/bender/caddy/Caddyfile:/etc/caddy/Caddyfile \
  -e CF_API_TOKEN=REDACTED \
  iarekylew00t/caddy-cloudflare:latest
  acme_dns cloudflare {env.CF_API_TOKEN}
notes.alfredoautomation.com {
	reverse_proxy	10.0.0.96:5230
	redir	/auth	/explore
cloud.alfredoautomation.com {
	reverse_proxy	https://10.0.0.96:444
rss.alfredoautomation.com {
	reverse_proxy	10.0.0.96:8085
sso.alfredoautomation.com {
	reverse_proxy	https://10.0.0.96:9444
photos.alfredoautomation.com {
	reverse_proxy	http://10.0.0.96:2283
food.alfredoautomation.com {
	reverse_proxy	10.0.0.96:4580
I think I figured out what I was doing wrong.
I changed nextcloud to run on port 80 instead of 443 and removed the tls skip verify and let caddy just auto https it.
