v2.5.0-rc.1
docker run -d --name caddy-front -p 8082:80 -p 443:443 -v /mnt/HD/HD_a2/Laurent/caddy-front/Caddyfile:/etc/caddy/Caddyfile -v /mnt/HD/HD_a2/Laurent/caddy-front/data:/data -v /mnt/HD/HD_a2/Laurent/caddy-front/config:/config -e CLOUDFLARE_EMAIL=myemail -e CLOUDFLARE_API_TOKEN=mytoken -e ACME_AGREE=true --restart always --net dnsnet_iphole --ip 10.0.0.100 gandulf78/caddy-ddns-cloudflare
Docker on ARMv7
See above
ARG CADDY_VERSION=2.5.0-rc.1
FROM caddy:${CADDY_VERSION}-builder AS builder
ENV GOOS=linux
ENV GOARCH=arm
ENV GOARM=7
ENV XCADDY_VERSION v0.2.1
RUN xcaddy build ${CADDY_VERSION}
–with GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare
–with GitHub - mholt/caddy-dynamicdns: Caddy app that keeps your DNS records (A/AAAA) pointed at itself.
FROM caddy:${CADDY_VERSION}-alpine
email myemail
acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
# Global Option Block
dynamic_dns {
provider cloudflare {env.CLOUDFLARE_API_TOKEN}
domains {
withlovefromfrance.fr test
The Cloudflare DNS records are not updated.
“level”:“debug”,“ts”:1650464856.4456823,“logger”:“dynamic_dns”,“msg”:“beginning IP address check”}
{“level”:“info”,“ts”:1650464856.8964326,“logger”:“pki.ca.local”,“msg”:“root certificate is already trusted by system”,“path”:“storage:pki/authorities/local/root.crt”}
{“level”:“info”,“ts”:1650464856.9010324,“msg”:“autosaved config (load with --resume flag)”,“file”:"/config/caddy/autosave.json"}
{“level”:“info”,“ts”:1650464856.9025605,“msg”:“serving initial configuration”}
{“level”:“info”,“ts”:1650464856.925188,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/data/caddy”}
{“level”:“info”,“ts”:1650464856.947096,“logger”:“tls”,“msg”:“finished cleaning storage units”}
{“level”:“error”,“ts”:1650464857.8098621,“logger”:“dynamic_dns”,“msg”:“unable to lookup current IPs from DNS records”,“error”:“got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}]”}
{“level”:“warn”,“ts”:1650464858.3861866,“logger”:“dynamic_dns.ip_sources.simple_http”,“msg”:“IPv6 lookup failed”,“endpoint”:“https://api64.ipify.org”,“error”:“Get “https://api64.ipify.org”: dial tcp6: lookup api64.ipify.org on 127.0.0.11:53: no such host”}
{“level”:“info”,“ts”:1650464858.3862958,“logger”:“dynamic_dns”,“msg”:“different IP address”,“new_ip”:“79.83.200.71”}
{“level”:“info”,“ts”:1650464858.3863792,“logger”:“dynamic_dns”,“msg”:“updating DNS record”,“zone”:“withlovefromfrance.fr”,“type”:“A”,“name”:“test”,“value”:“79.83.200.71”,“ttl”:1800}
{“level”:“error”,“ts”:1650464859.1720996,“logger”:“dynamic_dns”,“msg”:“failed setting DNS record(s) with new IP address(es)”,“zone”:“withlovefromfrance.fr”,“error”:“got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}]”}
{“level”:“info”,“ts”:1650464859.172176,“logger”:“dynamic_dns”,“msg”:“finished updating DNS”}
Check that TLS ACME certificates are get properly.
