dogrocker
(Kanin Peanviriyakulkit)
November 15, 2017, 11:23am
1
Hello! I was ran to the problem of Letsencrypt rate limit 5 certificates per week (rate-limits ).
So I need to disable auto redirect to https
this is my code for now
https://*.site.com {
proxy / localhost:8000 {
except /media /static
rewrite /static {
r (.*)
to /static_cdn/{1}
tls mymail@gmail.com
max_certs 3
root /opt/src
gzip
http://*.site.com {
rewrite /static {
r (.*)
to /static_cdn/{1}
root /opt/src
gzip
The problem is when I try to connect to http://abc.site.com it alway redirect to https://abc.site.com , But if I connect to http://abc.site.com/login it work.
Since you’re using Automatic HTTPS and the configurations are the same, you can just combine both labels on the same site definition:
http://*.site.com, https://*.site.com {
rewrite /static {
r (.*)
to /static_cdn/{1}
max_certs 3
root /opt/src
gzip
Caddy will then behave the same regardless of which scheme is used.
If you’re still getting redirected to HTTPS, I’d suggest making sure your browser cache is clear, and checking that the app at localhost:8000
isn’t actually doing the redirecting.
system
(system)
Closed
February 14, 2018, 12:12am
3
