Hello, I got following usecase:
- User calls
GET /path/1
/path/1
is proxied to service A that resolves path to/redirection/path/1
and sends it in X-Accel-Redirect header. - New, generated path, as it begins with
redirection
is redirected to external server.
internal
itself works, redir
itself works, but the problem is that Caddy is looking for path returned in X-Accel-Header (/redirection/path/1
) and does not redirect it as specified in Caddyfile. Does it even possible to manipulate (redir/rewrite) paths that are returned in X-Accel-Proxy? Unfortunately, I can’t bypass generating
correct path so I don’t know if there’s any other method to cover my usecase.
My Caddyfile:
:8033
bind 0.0.0.0
log / stdout "{combined}"
root /home/jjlakis/caddytest
# Redirect /redirection/something to external_service/something
redir {
if {path} starts_with /redirection
/ http://localhost:8034{rewrite_uri}
rewrite {
r ^/redirection/(.*)$
to /{1}
# Proxy /path/something to service that returns path /redirection/something
proxy /path localhost:3333 {
without /path
internal redirection
Redirection itself works:
$ curl -L -i localhost:8033/redirection/duck
HTTP/1.1 301 Moved Permanently
Server: Caddy
Date: Thu, 04 Oct 2018 09:30:19 GMT
Content-Length: 61
Content-Type: text/html; charset=utf-8
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 26
Etag: "pg0zk7q"
Last-Modified: Wed, 03 Oct 2018 13:45:43 GMT
Server: Caddy
EXTERNAL_RESOURCE_CONTENT
Proxy server:
$ curl -i -L http://localhost:3333/duck
HTTP/1.1 200 OK
X-Accel-Redirect: /redirection/duck
Date: Thu, 04 Oct 2018 10:04:51 GMT
Content-Length: 2
But this call is looking for /redirection/duck
file in root instead of redirecting it:
$ curl -L -i localhost:8033/path/duck
HTTP/1.1 404 Not Found
Content-Length: 19
Date: Thu, 04 Oct 2018 09:34:44 GMT
Server: Caddy
X-Content-Type-Options: nosniff
404 page not found
Thanks in advance
