Does anyone know if it’s possible to pause Caddy from issuing new or renewing certs, but still continuing to serve traffic on existing certs?
I issue certs using on_demand_tls and server traffic using reverse_proxy. Using caddy 2.4.6.
I’m currently working on a migration which involves switching Caddy to a new filesystem. I’d like to be able to perform the following steps;
- Pause the existing caddy install from issuing new or renewing certs
- Copy cert files across to the new system
- Point traffic to the new system
- Verify that new caddy system is serving traffic correctly
- Turn off old system
- Enable renewing / issuing new certs on the new system.
If not does, anyone have any ideas on how the migration might be performed with a minimal disruption? I have some ~200 certs so while I could just issue new certs on the new system and still be within rate limits but it doesn’t give me much room if I need to roll back.
Thanks in advance!
