v2.1.0
caddy run -config /etc/caddy/Caddyfile
CentOS 7
root * /usr/share/caddy
My app allow user to custom their domain(cname dns), Is it possible to enable TLS for any domains with wildcard?
./caddy run -config /etc/caddy/Caddyfile -watch
2020/06/29 07:11:31 WARNING: proto: file "pb.proto" is already registered
A future release will panic on registration conflicts. See:
https://developers.google.com/protocol-buffers/docs/reference/go/faq#namespace-conflict
2020/06/29 11:11:32.048 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
2020/06/29 11:11:32.058 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2020/06/29 07:11:32 [INFO][cache:0xc0006dfce0] Started certificate maintenance routine
2020/06/29 11:11:32.058 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/06/29 11:11:32.058 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/06/29 11:11:32.060 INFO tls cleaned up storage units
2020/06/29 11:11:32.061 INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
2020/06/29 11:11:32.061 INFO serving initial configuration
2020/06/29 11:11:32.061 INFO watcher watching config file for changes {"config_file": "/etc/caddy/Caddyfile"}
2020/06/29 07:11:52 http: TLS handshake error from 223.73.237.8:51188: no certificate available for 'ssl.razonyang.com'
2020/06/29 07:11:53 http: TLS handshake error from 223.73.237.8:51191: no certificate available for 'ssl.razonyang.com'
