WoJ
(WoJ)
May 9, 2019, 1:35pm
1
I use caddy
to proxify traffic to docker containers and would like to restrict access based on IPs. I cannot use plugins, so the optimal way would be to conditionally rewrite to a proxy
if {remote} starts_with 192.168 then proxy / x.x.x.x
The else
does not matter, provided the traffic is not sent to x.x.x.x
Is this something possible to do?
It’s not too difficult. You were pretty close to the mark in the other post that you deleted.
There’s two ways about it:
A) Proxy by default, forbidding bad clients
proxy / upstream
rewrite {
if {remote} not_starts_with 192.168
to /forbidden
status 403 /forbidden
B) Do something else by default (e.g. serve files), but proxy good clients:
root /var/www/html
rewrite {
to /proxy
proxy /proxy upstream {
without /proxy
matt
(Matt Holt)
May 10, 2019, 9:34pm
3
FYI, this is much easier (and makes way more sense) in Caddy 2.
WoJ
(WoJ)
May 13, 2019, 3:50pm
4
@matt Thank you - I will have a closer look to Caddy 2 now that I have deployed it successfully on my home servers.
system
(system)
Closed
August 11, 2019, 3:50pm
5
