v2.2.1
As a systemd service on raspbian. Caddyfile in /etc/caddy/.
Raspbian 7
caddy run / caddy adapt / caddy reload
N/A(?)
#snippet to detefine logging
(logging) {
output file /var/log/access.log
#snippet to determine whether hosts are inside or outside LAN.
(ip_match) {
@lan_hosts {
remote_ip 10.10.1.1/24 {$VPNIP}
@not_lan_hosts {
not {
#snippet to deny access to hosts from outside LAN
(access_denied) {
respond @not_lan_hosts "Access Denied" 403 {
close
pve.rmwhite.us {
import logging
import ip_match
import access_denied
reverse_proxy @lan_hosts {
to 10.10.1.50:8006
tls_insecure_skip_verify
I am working from home connected to a VPN. My desktop gets a different IP address every day, but I still need to use my local services. I would like to be able to update my primary computer’s VPN IP via a script. I am attempting to assign this VPN IP to an environment variable ($VPNIP) so I can simply update that variable, caddy reload, and have access to my local services.
The allow and deny blocks are entered as snippets in the beginning of my caddyfile.
If I enter the environment variable in the form {$VPNIP}, running “caddy adapt” just shows that caddy is ignoring the environment variable. That is to say, if I had:
remote_IP 10.10.1.1/24 {$VPNIP}
the caddyfile is parsed as:
[{“remote_ip”:{“ranges”:[“10.10.1.1/24,”]}}]
which ignores the environment variable, but caddy will run.
If I use the format {env.VPNIP}, I get the same output as above from caddy adapt, but caddy reload provides the error:
reload: sending configuration to instance: caddy responded with error: HTTP 400: {“error”:"loading config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module ‘subroute’: provision http.handlers.subroute: setting up subroutes: route 0: loading matcher modules: module name ‘not’: provision http.matchers.not: loading matcher sets: module name ‘remote_ip’: provision http.matchers.remote_ip: invalid IP address: "}
and caddy will not run.
I tried both of the environment variable formats I’ve found in the documentation.
