1. Output of caddy version
v2.6.0-beta.3 h1:2VFvttWPkJPEhXep+4vtDLcevGs2gS7z41ruJGymaYI=
From Konsole terminal.
openSUSE Tumbleweed 20220820
caddy run --config Caddyfile.json --adapter ""
N/A
"apps": {
"http": {
"http_port": 8888,
"servers": {
"srv0": {
"listen": [
":8888"
"routes": [
"handle": [
"handler": "headers",
"response": {
"set": {
"Access-Control-Allow-Origin": [
"match": [
"path": [
"/m2m/st/local/*"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "rewrite",
"method": "POST",
"strip_path_prefix": "/m2m/st/local"
"handle": [
"handler": "reverse_proxy",
"transport": {
"dial_timeout": 20000000000,
"protocol": "http"
"upstreams": [
"dial": "localhost:8081"
I’m using caddy as a reverse_proxy. Just a question.
I’m doing a POST to http://localhost:8888/m2m/st/local/system/healthcheck/tdv and that post includes an XML payload expected by the server
caddy redirects to http://localhost:8081/system/healthcheck/tdv
This works just fine.
My question is, can I convert the original request to caddy to a GET and have caddy change the GET to a POST and add the payload to the body to send to the server?
I can add
"method": "POST"
to the rewrite handler, but can’t find a way to add anything to the body.
N/A
N/A
