Import with reverse_proxy doesn't work
I have several reverse_proxy settings separated by sub-path. Usually, they are similar, so I try to remove duplicate code using import, but it doesn’t work well.
You can see my add_proxy snippet which generates like below.
handle_path /sam* {
		reverse_proxy localhost:3000 {
			header_up X-Real-IP {remote}
		rewrite * /token{path}
502 error for all reverse_proxy entries.
unknown (maybe 2.6.x, upgraded yesterday)
apk add caddy (alpine linux)
alpine linux 3.18.0, x64, running alpine by rc-service
no docker use
collabora.aaaa.com {
		output file /var/log/caddy/collabora.log
	reverse_proxy 192.168.0.50:9980 {
(add_proxy) {
	handle_path /{args[0]}* {
		reverse_proxy {args[1]} {
		rewrite * /{args[2]}{path}
(add_header) {
proxy.aaaa.com {
		output file /var/log/caddy/proxy.log
	@ws {
		header Connection *Upgrade*
		header Upgrade websocket
	handle_path /eos* {
		reverse_proxy 1.2.3.4:8888 {
	handle_path /kon* {
		reverse_proxy https://api.kon-wallet.com {
	handle_path /arbitrum* {
		reverse_proxy https://arbitrum-sepolia-rpc.dedicated.allthatnode.com {
			import add_header
		rewrite * /ffeda5ffd7{path}
	#handle_path /sam* {
	#	reverse_proxy localhost:3000 {
	#		header_up X-Real-IP {remote}
	#		header_up Host {upstream_hostport}
	#	rewrite * /token{path}
	import add_proxy sam localhost:3000 token
	handle_path /ripple* {
					reverse_proxy s1.ripple.com:443 {
		respond "not found" 404
What do you mean by “doesn’t work well”? What “doesn’t work”, exactly?
You didn’t share any logs or error messages. You didn’t describe the problem. We can’t help without more information.
That’s an old version, the latest is 2.7.6.
Please run the caddy version command to check the version.
After adding import directive (add_proxy), all handle_path inside proxy.aaaa.com block returns 502 Bad Gateway with no response body.
this is my import directive
(add_proxy) {
and used it like below.
You can see the exact locations are original post.
And here’s log for two consecutive requests
  1. POST proxy.singingdeveloper.com/sam
  2. POST proxy.singingdeveloper.com/arbitrum
2024/02/06 13:11:15.409 DEBUG   http.handlers.rewrite   rewrote request {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "/sam", "headers": {"Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"], "Content-Length": ["93"], "Content-Type": ["application/json"], "User-Agent": ["PostmanRuntime/7.36.1"], "Accept": ["*/*"], "Postman-Token": ["b7fa194e-7b28-419a-b2d5-514d8f6832a8"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "method": "POST", "uri": "sam"}
2024/02/06 13:11:15.409 DEBUG   http.handlers.rewrite   rewrote request {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "sam", "headers": {"User-Agent": ["PostmanRuntime/7.36.1"], "Accept": ["*/*"], "Postman-Token": ["b7fa194e-7b28-419a-b2d5-514d8f6832a8"], "Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"], "Content-Length": ["93"], "Content-Type": ["application/json"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "method": "POST", "uri": "/sam"}
2024/02/06 13:11:15.409 ERROR   http.log.error.log2     making dial info: upstream {args[1]}: invalid dial address : missing port in address    {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "/sam", "headers": {"Accept": ["*/*"], "Postman-Token": ["b7fa194e-7b28-419a-b2d5-514d8f6832a8"], "Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"], "Content-Length": ["93"], "Content-Type": ["application/json"], "User-Agent": ["PostmanRuntime/7.36.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "duration": 0.000073521, "status": 502, "err_id": "j38i4zt35", "err_trace": "reverseproxy.statusError (reverseproxy.go:1299)"}
2024/02/06 13:11:20.842 DEBUG   http.handlers.rewrite   rewrote request {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "/arbitrum", "headers": {"Content-Length": ["93"], "Content-Type": ["application/json"], "User-Agent": ["PostmanRuntime/7.36.1"], "Accept": ["*/*"], "Postman-Token": ["99038593-aca3-462a-8bb4-5bcf3be208b6"], "Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "method": "POST", "uri": "arbitrum"}
2024/02/06 13:11:20.842 DEBUG   http.handlers.rewrite   rewrote request {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "arbitrum", "headers": {"Content-Type": ["application/json"], "User-Agent": ["PostmanRuntime/7.36.1"], "Accept": ["*/*"], "Postman-Token": ["99038593-aca3-462a-8bb4-5bcf3be208b6"], "Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"], "Content-Length": ["93"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "method": "POST", "uri": "/arbitrum"}
2024/02/06 13:11:20.842 ERROR   http.log.error.log2     making dial info: upstream {args[1]}: invalid dial address : missing port in address    {"request": {"remote_ip": "14.52.161.35", "remote_port": "52849", "proto": "HTTP/1.1", "method": "POST", "host": "proxy.singingdeveloper.com", "uri": "/arbitrum", "headers": {"Accept-Encoding": ["gzip, deflate, br"], "Connection": ["keep-alive"], "Content-Length": ["93"], "Content-Type": ["application/json"], "User-Agent": ["PostmanRuntime/7.36.1"], "Accept": ["*/*"], "Postman-Token": ["99038593-aca3-462a-8bb4-5bcf3be208b6"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "proxy.singingdeveloper.com"}}, "duration": 0.000072874, "status": 502, "err_id": "afksguzgj", "err_trace": "reverseproxy.statusError (reverseproxy.go:1299)"}
and same request body is used
	"jsonrpc":"2.0",
	"method":"eth_getBlockByNumber",
	"params":["latest", false],
	"id": 1
caddy version says unknown exactly what I’ve said earlier, but I upgraded yesterday and I would be 2.7.6-r0(Alpine Linux packages).
Ah, right. The alpine packaging team is building incorrectly, so version information is not preserved properly. Sigh.
Here’s your problem. Your snippet didn’t produce a valid config.
Use caddy adapt -p to check the JSON config that your Caddyfile generates.
caddy adapt -p works well,
here’s part of it. args are not parsed I think.
  "group": "group8",
  "handle": [
      "handler": "subroute",
      "routes": [
          "handle": [
              "handler": "rewrite",
              "strip_path_prefix": "/{args[0]}"
          "group": "group0",
          "handle": [
              "uri": "/{args[2]}{http.request.uri.path}"
          "handle": [
              "handler": "reverse_proxy",
              "headers": {
                "request": {
                  "set": {
                    "Host": ["{http.reverse_proxy.upstream.hostport}"],
                    "X-Real-Ip": ["{http.request.remote}"]
              "upstreams": [
                  "dial": "{args[1]}"
  "match": [
      "path": ["/{args[0]}*"]
am i missing something basic about import?
If you’re actually using an older version of Caddy, then {args[0]} syntax didn’t exist and therefore it would fail.
I don’t have any way to help you verify you actually have the latest version, because clearly the Alpine releases don’t have it.
I suggest grabbing an official release from GitHub and using that instead, if you’re not able to guarantee you’re getting the latest release from the Alpine repo.
I picked latest version from github, and everything works like a charm.
All my efforts from yesterday is ended in sudden :melting_face:
My caddy version is
v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=.
For clarify, I tried upgrade caddy binary again from alpine repo,
apk update --no-cache
apk upgrade caddy --no-cache
but still got error, also shows version unknown.
Alpine crews need to work harder :slight_smile:
Thank you for your help! @francislavoie
Ahhh I see the problem:
https://pkgs.alpinelinux.org/packages?name=caddy&branch=v3.18&repo=&arch=&maintainer=
You said you’re on Alpine 3.18. That’s an older version, and therefore doesn’t have the latest packages. You were getting Caddy v2.6.4.
If you switch to 3.19 or “edge”, you’d have the latest.
