From Termux (Android), I use:
cd /
caddy file-server -browse -listen 0.0.0.0:8000
Some directory listings (e.g., the root /
one) are not generated successfully, and show as blank pages in the browser. Their subdirectories and files are fine.
Caddy does not produce any errors, but having tried GitHub - m3ng9i/ran: a simple static web server written in Go as well, where a similar thing happens, the issue seems to be that there are some directories such as /.cache
that the user running caddy does not have the permission to read. The parents of these unreadable directories then will not have their listings generated.
Is there any way to just ignore such errors?
