If/else (conditional) on Caddy V2?
Hi. I have been searching for a while for the usage of if/else. I found a couple of posts made a few years back, but there is no recent post about this.
How do I use if/else in Caddy V2? Is there a documentation for it? Because i cannot find any. Can Caddy V2 even use if/else?
Thank you!
Use request matchers. What kind of logic are you looking to implement?
I have multiple domains that I frequently changing their subdomain.
Let say I got these domains:
I want to redirect example.com/.net/.org and all subdomains to ww10
Something like, if subdomain is not ww10, redirect to ww10
I think I got it.
    @redirect {
        expression `{http.request.host.labels.2} != "ww10"`
    redir @redirect https://ww10.{http.request.host.labels.1}.{http.request.host.labels.0}
But can I specify example.com and *.example.com without writing them both? Tried *example.com with no luck
You can shorten the placeholders to {labels.2}, see the placeholder shortcuts available in the Caddyfile:
You can use a header_regexp Host matcher instead of the host matcher to match the hostname how you want.
The host matcher does not cross label boundaries with *, by design, to match certificate matching logic.
Thanks a lot!
