Hi,
I am trying to invoke authentication only when a request comes from outside my LAN range. I have tried the following which if found somewhere in the documentation but it doesnt work. Unknown directive {{if
{{if not eq .Ip "10.0.0.10"}}
basicauth / username **********
{{end}}
Here are related notes from my testing several months ago; with luck, you may find something useful:
## produce 404 when requested by 10.0.0.36
ipfilter /private/ {
rule block
ip 10.0.0.36/32
## for non-local requests, returns page at / but does not show / in the address bar
rewrite /localonly/ {
if {remote} not_starts_with 10.0.0.
to /
## for non-local requests, redirects to / and shows / in the address bar
redir 307 {
/localonly2/ /
## yes, redundant but shows we can redirect any non-local request anywhere we like
## wanted to test this to prove that caddy would be able to properly obtain a cert
## while blocking any other remote requests - and it worked flawlessly
redir 307 {
/ https://google.com
One issue is that basicauth can’t really be scoped inside a site block except by base path.
If I recall correctly, the last time this came up, one recommendation was configuring two sites, e.g. secure.example.com and open.example.com, with a Caddyfile like:
open.example.com {
# Serve site without auth
root /var/www/html
# Redirect non-LAN IPs to secure site
redir {
if {remote} not_starts_with "10."
if {remote} not_starts_with "192.168."
/ https://secure.example.com{uri}
secure.example.com {
# Serve site with basicauth
basicauth / username password
root /var/www/html
# Redirect LAN IPs to open site
redir {
if_op or
if {remote} starts_with "10."
if {remote} starts_with "192.168."
/ https://open.example.com{uri}
What i ended up doing is the following. Each service has its own section after the ###### header. Just copy-paste and replace the values to add new reverse-proxies. This uses namecheap DNS-01 for SSL.
