Hello,
In my use case I try to provide an emberjs application.
For this use case caddy should be able to do this, it is a HTML5 / CSS / JS static website.
Normal HTML5 / CSS / JS works fine but I have some static json files which are used for test data.
The json files are delivered with contentType text/html. I know this is the default behaivior.
I tried to solve this problem using the mime directive.
I use caddy 0.9.2 64Bit windows version ==> I use Windows 10
THe content of my Caddy file looks like:
*:2020 {
root ./dist
mime .json application/json
After starting caddy with this Caddyfile content I get an error:
Activating privacy features…2016/09/23 08:56:39 [mime] failed to get certificate: acme: Error 400 - urn:acme:error:malformed - DNS name does not have enough labels
I don’t want use https currently.
I tried the same using linux and got the same error.
I use the the Caddyfile without the mime directive with OSX and the json files were delivered with application/json contentType per default.
What is wrong here ?
Best regards
Andreas
