caddy start
paste command here
I am not able to convert v1 to v2 because as I read some document directive are different, could you please assist me to change v1 to v2 caddyfile
#### c. Service/unit/compose file:
<!-- If using Docker/systemd/Kubernetes/make etc. -->
paste full file contents here
auth.ot.loc:80 {
proxy / {$ENV_F_HOST}:3000 {
proxy /api localhost:3002 {
proxy /oauth localhost:3002 {
proxy /sockjs-node {$ENV_F_HOST}:3000 {
websocket
agency.ot.loc:80 {
proxy / {$ENV_F_HOST}:3001 {
proxy /api localhost:3003 {
proxy /oauth localhost:3003 {
proxy /uploads localhost:3003 {
proxy /rental_applications localhost:3003 {
proxy /sockjs-node {$ENV_F_HOST}:3001 {
websocket
#### d. My complete Caddyfile or JSON config:
### 3. The problem I'm having:
<!-- What are you trying to do, and what isn't working? Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you're seeing. Be as specific as possible. -->
### 4. Error messages and/or full log output:
<!-- Please **DO NOT REDACT** any information except credentials. -->
### 5. What I already tried:
<!-- Show us what effort you've put in to solving the problem. Be specific -- people are volunteering their time to help you! Low effort posts are not likely to get good answers! -->
### 6. Links to relevant resources:
