HTTPS SRV upstream for reverse proxy
I cannot make SRV upstream work in HTTPS mode in the recent version of Caddy. In previous versions, the following short directive worked as expected:
api.example.com {
  route {
    reverse_proxy srv+https://_https._tcp.hello.services.example.com {
However, in Caddy 2.7.3 it no longer works with the following error:
"dial tcp: lookup _https._tcp.hello.services.example.com on [fdaa::3]:53: no such host"
DNS SRV record:
> dig +short srv _https._tcp.hello.services.example.com
0 0 443 p02.host.example.com.
Another approach seems to solve the issue with DNS lookup:
api.example.com {
  route {
    reverse_proxy {
      dynamic srv {
         name hello.services.example.com
         service https
         proto tcp
But Caddy then uses HTTP instead of HTTPS, despite the specified https service and 443 port in the SRV DNS record.
Is there a way to make an SRV upstream work with HTTPS protocol?
You need to add this:
	tls
Using https:// is a shortcut for configuring the transport. See reverse_proxy (Caddyfile directive) — Caddy Documentation which explains.
