2.3.0
Caddy-docker-proxy
Caddy-docker-proxy via docker-compose on host Ubuntu Budgie 20.10.
Not aware. caddy-docker-proxy takes care of everything.
Just the labels for the relevant service, since all other services work fine using my own online domain name:
##_____________________ Heimdall [Management/HOMEPAGE]
organizr:
container_name: organizr
image: organizr/organizr:latest
restart: always
- management
security_opt:
- no-new-privileges:true
fpm: 'true'
- $DOCKERDIR/organizr:/config
labels:
caddy: "http://o.belix"
caddy.reverse_proxy: "{{upstreams 80}}"
email domain@name.com
suba.domain.com {
X-Content-Type-Options none
X-Frame-Options DENY
X-XSS-Protection "1; mode=block;"
reverse_proxy /notifications/hub 172.26.0.3:3012
reverse_proxy /notifications/hub/negotiate 172.26.0.3:80
reverse_proxy 172.26.0.3:80
subb.domain.com {
Strict-Transport-Security max-age=15768000;
X-Frame-Options SAMEORIGIN
reverse_proxy 172.26.0.7:80 {
header_up Host subb.domain.cloud
subc.domain.com {
reverse_proxy 172.26.0.2:5000
http://local.lan {
reverse_proxy
subd.domain.com {
reverse_proxy 172.26.0.5:80
sube.domain.com {
reverse_proxy 172.26.0.6:8384
My internet domain with subdomains work, I can use https://suba.domain.com, https://subb.domain.com, …, …, …, https://sube.domain.com
→ However in my router, purely for local lan, I created a domain local.lan
that forwards to my server ip (192.168.88.2). I would like to use TLS for it (https://local.lan) without exposing this outside of my LAN.
That part does not work:
https://local.lan
Secure Connection Failed
An error occurred during a connection to o.belix. Peer reports it experienced an internal error.
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
instead of {{ upstreams 80 }}
I tried {{ localhost 80 }}
which leads to an error in Caddy.
