1. Output of caddy version
Ubuntu 20.04, apt installed
Trying to reach from Brave Browser, mobile Chrome and mobile DuckDuckGo.
running caddy using systemd
(error404) {
handle_errors {
root * /var/www/drankganzenbord.nl/html
@404 {
expression {http.error.status_code} == 404
rewrite @404 /404.html
www.drankganzenbord.nl, drankganzenbord.nl {
handle / {
php_fastcgi / unix//var/run/php/php7.3-fpm.sock
import error404
The site is missing a valid, trusted certificate. Checking the chain shows that the Fireware HTTPS Proxy certificate isn’t valid.
What even is WatchGuard and Fireware?
user@morvigor:~$ curl -v https://drankganzenbord.nl
* Trying 185.95.13.16:443...
* TCP_NODELAY set
* Connected to drankganzenbord.nl (185.95.13.16) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* subject: CN=drankganzenbord.nl
* start date: Aug 16 14:03:39 2022 GMT
* expire date: Nov 14 14:03:38 2022 GMT
* subjectAltName: host "drankganzenbord.nl" matched cert's "drankganzenbord.nl"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x55a55efe48c0)
> GET / HTTP/2
> Host: drankganzenbord.nl
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 200
< content-type: text/html; charset=UTF-8
< server: Caddy
< date: Tue, 16 Aug 2022 15:29:20 GMT
Deleted all the certificates in /var/lib/caddy/.local/ and rebooted the system.
Used an online TLS checker to validate that it’s not just my browser.
