first thanks francislavoie for your response.
Updated Caddy version to v2.4.6.
Log after running command:
journalctl -u caddy --no-pager | less +G
What I understand from the below port 80 is being used by another service, if that is correct are you aware how to dedicate port 80 for caddy alone.
on :80: listen tcp :80: bind: address already in use
Jan 18 03:17:52 raspberrypi systemd[1]: Started Caddy.
Jan 18 03:17:52 raspberrypi systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 03:17:52 raspberrypi systemd[1]: caddy.service: Failed with result 'exit-code'.
-- Boot 3e63c6057836473e881465f3eed677bd --
Jan 18 06:51:46 biggs-cloud.tk systemd[1]: Starting Caddy...
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: caddy.HomeDir=/var/lib/caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: caddy.Version=v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.GOOS=linux
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.GOARCH=arm
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.Compiler=gc
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.NumCPU=4
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.GOMAXPROCS=4
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: runtime.Version=go1.17
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: os.Getwd=/
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: LANG=C.UTF-8
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: NOTIFY_SOCKET=/run/systemd/notify
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: HOME=/var/lib/caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: LOGNAME=caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: USER=caddy
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: INVOCATION_ID=7d77f1a7b1924919809777948e309629
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: JOURNAL_STREAM=8:18432
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8401392,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8834755,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8842256,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8843312,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8864322,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8876467,"logger":"tls","msg":"finished cleaning storage units"}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.8851957,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x34d6690"}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: {"level":"info","ts":1642495925.899863,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0x34d6690"}
Jan 18 06:52:05 biggs-cloud.tk caddy[1027]: run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: address already in use
Jan 18 06:52:05 biggs-cloud.tk systemd[1]: Started Caddy.
Jan 18 06:52:05 biggs-cloud.tk systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 06:52:05 biggs-cloud.tk systemd[1]: caddy.service: Failed with result 'exit-code'.
-- Boot e00f79b23086433db1ad4b83e1713a5d --
Jan 21 17:16:59 biggs-cloud.tk systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
