I am encountering an issue with my Caddy installation.
caddy version
2943c41884278ec5fc44bcb55d2b9b088838cdc2+modified (24 Apr 23 16:36 UTC)
I have installed the latest release from GitHub using xcaddy and have noticed that HTTP3 does not work for IPv4
and IPv6
. When I try to access my website via IPv4
HTTP3 does not work. When I ran the command netstat -tulpn | grep caddy
, it printed udp6
but no udp
neither say LISTEN
. tcp says LISTEN
The output of this command is:
tcp 0 0 127.0.0.1:2019 0.0.0.0:* LISTEN 4397/caddy
tcp6 0 0 :::80 :::* LISTEN 4397/caddy
tcp6 0 0 :::443 :::* LISTEN 4397/caddy
udp6 0 0 :::443 :::* 4397/caddy
I have already opened the UDP port 443 from Digital Ocean and from Ubuntu UFW, but Caddy does not seem to be listening to UDP. Can you please guide me on how to tell Caddy to listen to UDP (IPv4 /IPv6) as well? My server is hosted on Digital Ocean.
When i do curl it’s not even work for http3
curl -I --http3 https://(domain goes here):443
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 460 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
HTTP/1.1 200 OK
Alt-Svc: h3=":443"; ma=2592000
Cache-Control: max-age=300
Content-Length: 460
Content-Type: text/html; charset=utf-8
Date: Sun, 30 Apr 2023 21:01:50 GMT
Server: Caddy
Also that when I tried accessing the website via Chrome browser, it would not load via H3 no matter how much I reloaded it.
I appreciate any help you can provide
