curl shows that http3 is enabled but browsers are not choosing it, they still choose to communicate over http2. I have been poking around different places but can’t figure out what is wrong.
docker run -it --rm ymuski/curl-http3 curl -vL -D/dev/stdout -o/dev/null --http3 https://imigrant.dk
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 172.104.142.58:443...
* CApath: none
* subjectAltName: host "imigrant.dk" matched cert's "imigrant.dk"
* Connected to imigrant.dk (172.104.142.58) port 443 (#0)
* using HTTP/3
* Using HTTP/3 Stream ID: 0 (easy handle 0x55f4dbb81410)
> GET / HTTP/3
> Host: imigrant.dk
> User-Agent: curl/8.1.2-DEV
< HTTP/3 200
HTTP/3 200
< content-type: text/html;charset=UTF-8
< last-modified: Fri, 21 Jul 2023 20:21:38 GMT
< cache-control: public, max-age=0, no-cache, no-transform
< content-security-policy: test
< x-xss-protection: 1; mode=block
< server: Caddy
server: Caddy
< vary: Accept-Encoding
< x-hyper-cache: hit - plain-https
< content-length: 33266
< x-powered-by: PHP
x-powered-by: PHP
< x-frame-options: DENY
{ [1035 bytes data]
100 33266 100 33266 0 0 240k 0 --:--:-- --:--:-- --:--:-- 242k
* Connection #0 to host imigrant.dk left intact
NixOS unstable, x86_64, systemd 253.5
The following comand is what the caddy.service executes.
/nix/store/8byahwsz6hgdynjjz9987gl0i6469mhj-caddy-2.6.4/bin/caddy run --config /etc/caddy/caddy_config --adapter caddyfile
The following is the caddy file as it gets compiled by nix and outputted in /etc/caddy/caddy_config.
servers {
protocols h1 h2 h3
level ERROR
imigrant.dk {
output file /var/log/caddy/access-imigrant.dk.log
root * /nix/store/1bmn7ligp6g3g8i2ryhyizm0palx5vmg-wordpress-imigrant.dk-6.2.2/share/wordpress
php_fastcgi unix/run/phpfpm/wordpress-imigrant.dk.sock
@uploads {
path_regexp path /uploads\/(.*)\.php
rewrite @uploads /
@wp-admin {
path not ^\/wp-admin/*
rewrite @wp-admin {path}/index.php?{query}
# Rewrite image paths to existent .webp files.
# Definition of supported images.
@images {
# Match supported image paths and extensions
path_regexp static (.*)\.(jpg|jpeg|gif|png)$
# Ensure we have an .webp file corresponding with selected path.
file {
# Definition of supported assets.
@assets {
path_regexp static (.*)\.(png|jp?g|gif|webp|ico|css|map|woff?|eot|svg|ttf|js)$
file {
try_files {path}
# Use compression.
encode {
gzip
# Compress the following MIME-Types.
match {
header Content-Type application/*
header Content-Type font/*
header Content-Type image/*
header Content-Type text/*
# Headers for assets.
handle @assets {
header cache-control "max-age=86400"
# Headers for /wp-admin/ paths.
handle /wp-admin/* {
header content-security-policy "admin"
# Headers for all other paths.
# Keep header names lowercased. They should be compared in a case-insensitive fashion.
# Prevent MIME type sniffing attacks.
x-content-type-options "nosniff"
# Prevent website from framing this site.
x-frame-options: "DENY"
# Prevent XSS in older browsers that don't support CSP.
x-xss-protection "1; mode=block"
content-security-policy "test"
# Replace the PHP signature from the existing headers, and don't set new headers where there aren't any.
x-powered-by ".*" "PHP"
# Delay assigning headers until everything is ready, essentially making this block authoritative.
defer
www.imigrant.dk {
output file /var/log/caddy/access-www.imigrant.dk.log
# Redirect www to non-www with https.
redir https://{labels.1}.{labels.0}{uri}
Caddy is built in NixOS using this definition: https://github.com/NixOS/nixpkgs/blob/master/pkgs/servers/caddy/default.nix
