1. Output of caddy version
Ubuntu 22.04 LTS → Nomad → Docker container
b. Command: caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
job "ingress" {
datacenters = ["..."]
group "g" {
network {
mode = "bridge"
port "http" {
static = 80
to = 80
port "https" {
static = 443
to = 443
service {
name = "ingress"
connect {
sidecar_service {
proxy {
upstreams {
destination_name = "aaa"
local_bind_port = 1111
upstreams {
destination_name = "bbb"
local_bind_port = 2222
task "caddy" {
driver = "docker"
config {
image = "pikeas/caddy:2.5.2"
volumes = ["local:/etc/caddy:ro"]
template {
data = local.caddy_config
destination = "local/Caddyfile"
volume_mount {
volume = "ingress"
destination = "/data"
volume "ingress" {
type = "host"
source = "ingress"
# inlined to job file as local template
acme_dns cloudflare ...
aaa.int.example.com {
reverse_proxy localhost:1111
bbb.int.example.com {
reverse_proxy localhost:2222
Caddy is proxying internal services. This is in a Nomad cluster, where Nomad makes those services available in the Caddy container’s namespace.
Those services work when hit directly, eg: curl http://localhost:1111
Caddy thinks everything is fine:
{"level":"info","ts":...,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/.../..."}
{"level":"info","ts":...,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/..."}
{"level":"info","ts":...,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"aaa.int.example.com"}
Everything is not fine:
$ curl https://localhost/ -H "Host: aaa.internal.example.com" -v
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
* CApath: none
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* Closing connection 0
I have two clues:
- Curl with
--resolve aaa.int.example.com:443:127.0.0.1
works, host header does not. - Only some services are failing, despite identical Caddy config blocks.
After enabling debug, there’s one additional line logged:
{"level":"debug","ts":...,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"localhost:1111","total_upstreams":1}
I’m a bit stumped on how to debug further.
