Noted.
Here’s the grep output:
$ grep 'user\|group' /etc/php/8.1/fpm/pool.d/*.conf
; Unix user/group of processes
; Note: The user is mandatory. If the group is not set, the default user's group
user = www-data
group = www-data
; and group can be specified either by name or by their numeric IDs.
; Default Values: user and group are set as the running user
listen.group = www-data
; these options, value is a comma separated list of user/group names.
; When set, listen.owner and listen.group are ignored
;listen.acl_users =
;listen.acl_groups =
; Set the process dumpable flag (PR_SET_DUMPABLE prctl) even if the process user
; or group is different than the master process user. It allows to create process
; core dump and ptrace the process for the pool user.
; user - the user (PHP_AUTH_USER) (or '-' if not set);
; user: -
; - remove a server from a group if it is not responding (load balancing);
; - %{user}C for user CPU only
; - %{total}C for user + system CPU (default)
; %u: remote user
; FPM to .php extensions to prevent malicious users to use other extensions to
Does this mean I need to change the owner back to www-data
for /var/www/wordpress
