): 2.4.6
running caddy in localhost to serve a html webpage.a. System environment:
Mac0s BigSur V11.2
caddy start
servers :443 {
protocol {
experimental_http3
localhost:443 {
root * /path to static page
With above mentioned caddy file I ran caddy to serve a static html page to see how http/3 works in caddy.
I ran https://localhost:443 but it is still serving it as h2 request.
pls guide me If I am missing something
2022/01/02 06:52:46.562 INFO using adjacent Caddyfile
2022/01/02 06:52:46.563 WARN input is not formatted with ‘caddy fmt’ {“adapter”: “caddyfile”, “file”: “Caddyfile”, “line”: 2}
2022/01/02 06:52:46.564 INFO admin admin endpoint started {“address”: “tcp/localhost:2019”, “enforce_origin”: false, “origins”: [“localhost:2019”, “[::1]:2019”, “127.0.0.1:2019”]}
2022/01/02 06:52:46.564 INFO tls.cache.maintenance started background certificate maintenance {“cache”: “0xc0002ca000”}
2022/01/02 06:52:46.564 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {“server_name”: “srv0”, “https_port”: 443}
2022/01/02 06:52:46.564 INFO http enabling automatic HTTP->HTTPS redirect{“server_name”: “srv0”}
2022/01/02 06:52:46.566 INFO tls cleaning storage unit {“description”: “FileStorage:/Users/mathivanan.paulraj/Library/Application Support/Caddy”}
2022/01/02 06:52:46.566 INFO tls finished cleaning storage units
2022/01/02 06:52:46.694 INFO pki.ca.local root certificate is already trusted by system {“path”: “storage:pki/authorities/local/root.crt”}
2022/01/02 06:52:46.694 INFO http enabling experimental HTTP/3 listener {“addr”: “:443”}
2022/01/02 06:52:46.694 DEBUG http starting server loop {“address”: “[::]:443”, “http3”: true, “tls”: true}
2022/01/02 06:52:46.694 DEBUG http starting server loop {“address”: “[::]:80”, “http3”: false, “tls”: false}
2022/01/02 06:52:46.694 INFO http enabling automatic TLS certificate management {“domains”: [“localhost”]}
2022/01/02 06:52:46.695 WARN tls stapling OCSP {“error”: “no OCSP stapling for [localhost]: no OCSP server specified in certificate”}
2022/01/02 06:52:46.695 DEBUG tls.cache added certificate to cache {“subjects”: [“localhost”], “expiration”: “2022/01/02 18:20:52.000”, “managed”: true, “issuer_key”: “local”, “hash”: “4ef5417e5c6a2e8a065b5ceaa4727f74c7516a406a0fe848881dc309bb8671b7”, “cache_size”: 1, “cache_capacity”: 10000}
I checked with my chrome browser, for other websites it could able to handle h3 requests
