Caddy version
v2.0.0-beta10 h1:MkLEoR4kj30H90sZ4YBg9O7sd4Zrl77H0m3mW9gyEmE=
[caddy2_beta10_linux_amd64] downloaded today from Release 2.0 beta 10 · caddyserver/caddy · GitHub
When running the binary against a minimal config file
./20191219-caddyv2 run -config ./caddy.conf --adapter caddyfile
where caddy.conf is
experimental_http3
go.yahvehyireh.com
root * /var/html/go.yahvehyireh.com/public
try_files {path}.html {path}
encode gzip zstd brotli
The server starts, with the following
2019/12/19 17:42:16.806 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["localhost:2019"]}
2019/12/19 17:42:16.807 INFO http enabling automatic TLS certificate management {"domains": ["go.yahvehyireh.com"]}
2019/12/19 17:42:16.807 INFO http enabling automatic HTTP->HTTPS redirects {"domains": ["go.yahvehyireh.com"]}
2019/12/19 17:42:16.807 INFO http enabling experimental HTTP/3 listener {"addr": ":443"}
**2019/12/19 17:42:16.808 INFO http enabling experimental HTTP/3 listener {"addr": ":444"}**
2019/12/19 17:42:16.808 INFO tls cleaned up storage units
2019/12/19 17:42:16.808 INFO admin Caddy 2 serving initial configuration
2019/12/19 17:42:16 [INFO][cache:0xc00009f9f0] Started certificate maintenance routine
as you see the experimental http/3 listens on a port one above 443 (as well as 443.)
When accessing https://go.yahvehyireh.com/
curl -I https://go.yahvehyireh.com/
The alt-srv header is
h3-23=":444"; ma=2592000
so the alternative service isn’t on the same port.
I can work around this by starting the server on port 442, at which point
gives a alt-srv header as:
h3-23=":443"; ma=2592000
and everything works as expected, tested.
