How would I use tls_insecure_skip_verify in my caddyfile?
I’m trying to get my browsers to ignore the certificate warning in my browser for the self-signed certificate caddy uses. I’ve preformed a few searches here but can’t make out what I’m supposed to do in my Caddyfile to get it working. I only need this for internal addresses, not external use. There is no external access to my local services.
https://caddyserver.com/docs/install#debian-ubuntu-raspbian
Ubuntu 23.10.1
# domain name.
	admin 0.0.0.0:2020
nc.sceptic.au: {
	tls internal
	reverse_proxy localhost:11000
sceptic.au {
        dns godaddy h1JeCcCMFBYt_2i4PUv5PejJKQJ353bhW34
    # Additional configuration for your local domain
    reverse_proxy localhost:443
sonarr.sceptic.au {
	tls internal
	reverse_proxy 192.168.50.242:8989
homepage.sceptic.au {
	tls internal
	reverse_proxy localhost:3000
overseerr.sceptic.au {
    tls internal
	reverse_proxy localhost:5055
maintainerr.sceptic.au {
	tls internal
	reverse_proxy localhost:8154
radarr.sceptic.au {
	tls internal
	reverse_proxy localhost:7878
readarr.sceptic.au {
	tls internal
	reverse_proxy localhost:8787
lidarr.sceptic.au {
	tls internal
	reverse_proxy localhost:8686
sabnzbd.sceptic.au {
	tls internal
	reverse_proxy localhost:8089
prowlarr.sceptic.au {
	tls internal
	reverse_proxy localhost:9696
https://audio.sceptic.au:443 {
	tls internal
	reverse_proxy localhost:13378
tautulli.sceptic.au {
	tls internal
	reverse_proxy localhost:8181
paperless.sceptic.au {
	tls internal
	reverse_proxy localhost:8003
actual.sceptic.au {
	tls internal
	reverse_proxy localhost:5006
freshrss.sceptic.au {
	tls internal
	reverse_proxy localhost:8282
immich.sceptic.au {
	tls internal
	reverse_proxy localhost:2283
dozzle.sceptic.au {
	tls internal
	reverse_proxy localhost:8888
ukuma.sceptic.au {
	tls internal
	reverse_proxy localhost:3001
filebrowser.sceptic.au {
	tls internal
	reverse_proxy localhost:8383
dockge.sceptic.au {
	tls internal
	reverse_proxy localhost:5001
linkding.sceptic.au {
	tls internal
	reverse_proxy localhost:9090
change.sceptic.au {
	tls internal
	reverse_proxy localhost:5000
duplicati.sceptic.au {
	tls internal
	reverse_proxy localhost:8200
stirlingpdf.sceptic.au {
	tls internal
	reverse_proxy localhost:8088
The solution is to install Caddy’s root CA cert in your system & browser’s trust store. Automatic HTTPS — Caddy Documentation
tls_insecure_skip_verify is specifically for reverse_proxy connecting to an HTTPS upstream, not for incoming connections. It’s almost never the right thing to use (hence the insecure in the name, to deter you from using it).
How would I make caddy trust use port 2020?
skepticalme@PlexServer:~$ caddy trust
Error: requesting CA info: performing request: Get "http://localhost:2019/pki/ca/local": dial tcp 127.0.0.1:2019: connect: connection refused
Run caddy trust --help, use the --address option or specify your config so it loads the admin address from it. You’ll need to run it with sudo so it has permissions to update trust stores.
Thank you, done.
With the browser, is there a way to obtain the certificate to load into Brave browser? I know how to load it, I just don’t know where to get the certificate. But now I think of it, is it found in the Ubuntu “trust store” on my machine?
Many browsers use their own trust stores. You’ll need to find out on your how to install root certs in Brave. You can get the cert file from Caddy’s storage to install it manually if necessary.
I added the root.crt from here:
/home/skepticalme/.local/share/caddy/pki/authorities/local
To brave and Firefox, but it didn’t work, they’re still giving the certificate warning.
I followed different guides on how to load the certificates into Firefox and Brave but no luck.
When running as a systemd service, the caddy user’s home is /var/lib/caddy, not /home.
Done! Thank you for your patience with me.
