How useful are css and js options for markdown?
I just tried to use the css and js options in markdown. I pointed them to the respective files to be included.
They were not included. How are they supposed to work?
In contrast, adding the relevant <link> and <script src=...> tags in the template file worked as expected (they were included).
The css/js are only included when using the default template; these subdirectives are for convenience if you don’t want to make up a whole template file. If you make your own template, you’re expected to include CSS/JS yourself.
I should clarify this in the docs, it’s an obvious omission.
