How to use plugins with docker?
Hey,
Is it possible to use caddy plugins when I use the docker container?
If yes, how?
See the docs on Docker Hub, there’s a section that explains how to write a Dockerfile to build with plugins. See “Adding custom Caddy modules”
This is my setup.
Dockerfile:
FROM caddy:2.7.5-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/hairyhenderson/caddy-teapot-module \
FROM caddy:2.7.5
Then docker build . will make the plugged image for you.
If you run this in a compose scenario, you just point your Caddy section to the local build instead of a public image:
    build:
      context: ./caddy
      dockerfile: Dockerfile
    restart: always
In this case the Dockerfile is located like:
caddy/Dockerfile
docker-compose.yml
