Hello.
I already wrote about my problem that my LetsEncrypt limit is used, and I’m now trying to use TLS Cloudflare.
This is my Caddyfile
www.{$DOMAIN_NAME} {
redir https://domain.com
{$DOMAIN_NAME} {
proxy / myapp:5000 {
header_upstream Host {host}
dns cloudflare
log stdout
errors stdout
gzip
But, if I run docker-compose -f production.yml up --build
, got error:
caddy_1 | 2018/01/15 13:59:07 /etc/Caddyfile:12 - Parse error: Unsupported DNS provider ‘cloudflare’
In the Dockerfile I added:
ARG plugins="git, cloudflare"
And now it looks like this:
FROM abiosoft/caddy:0.10.6
COPY ./compose/production/caddy/Caddyfile /etc/Caddyfile
But I keep getting the same mistake.
What am I doing wrong?
Based on the example from the Docker Hub page, I’m guessing the space in the middle of the variable is the problem. Try just comma-delimited, rather than comma-space-delimited.
From Docker Hub
docker build --build-arg \
plugins=filemanager,git,linode \
github.com/abiosoft/caddy-docker.git
I saw your example, but I do not understand how to use it in my case.
I’m using docker-compose
, and I’m not writing the docker build
command.
I gave an example of Dockerfile
And here is part of my production.ym
l file:
build:
context: .
dockerfile: ./compose/production/caddy/Dockerfile
depends_on:
- myapp
- caddy:/root/.caddy
env_file: .env
- "0.0.0.0:80:80"
- "0.0.0.0:443:443"
The example I provided wasn’t for use, it was for comparison. Specifically, note the format of the arg from the example I linked to:
Now compare with the example you provided:
git, cloudflare
Which led to the suggestion that perhaps you should try without a space:
No changes occurred, and still I get the error “Parse error: Unsupported DNS provider 'cloudflare'
”, regardless of whether a space is used after the comma.
Hmm. Did you do another docker build
after making changes?
abiosoft
(Abiola Ibrahim)
February 3, 2018, 10:32pm
#7
If you want to select plugins in your Dockerfile, you need to use abiosoft/caddy:builder
in a multi-stage build. Pulling from abiosoft/caddy
does not recompile Caddy.
The other option you have is to specify the git repo as the build context like it is done here .
system
(system)
closed
May 4, 2018, 10:32pm
#8
