How to use path reverse proxy with caddy as MITM proxy?
I have a public nginx which is removing the https request and pass it through to caddy as http.
I would like to map different paths to different backend services.
I think there is something missing regarding the first reverse proxy calling caddy, because if I try to connect via wget on the machine I can access the backend services.
curl -vL https://cloud..../uptime
* Host cloud....:443 was resolved.
* IPv6: (none)
* IPv4: 45.144....
*   Trying 45.144....:443...
* Connected to cloud.... (45.144....) port 443
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-AES256-GCM-SHA384 / [blank] / UNDEF
* ALPN: server accepted h2
*  subject: CN=cloud....
*  start date: Sep 18 11:18:11 2025 GMT
*  expire date: Dec 17 11:18:10 2025 GMT
*  subjectAltName: host "cloud...." matched cert's "cloud...."
*  issuer: C=US; O=Let's Encrypt; CN=R12
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://cloud..../uptime
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: cloud....]
* [HTTP/2] [1] [:path: /uptime]
* [HTTP/2] [1] [user-agent: curl/8.7.1]
* [HTTP/2] [1] [accept: */*]
> GET /uptime HTTP/2
> Host: cloud....
> User-Agent: curl/8.7.1
* Request completely sent off
< HTTP/2 200
< date: Fri, 19 Sep 2025 16:55:52 GMT
< content-length: 0
< strict-transport-security: max-age=15724800; includeSubDomains
* Connection #0 to host cloud.... left intact
  "level": "info",
  "ts": 1758301203.150556,
  "logger": "http.log.access",
  "msg": "NOP",
  "request": {
    "remote_ip": "100.119.85.210",
    "remote_port": "53972",
    "client_ip": "100.119.85.210",
    "proto": "HTTP/1.1",
    "method": "GET",
    "host": "cloud....",
    "uri": "/favicon.ico",
    "headers": {
      "X-Forwarded-Proto": [
        "https"
      "Sec-Fetch-Mode": [
        "no-cors"
      "X-Real-Ip": [
        "62...."
      "X-Scheme": [
        "https"
      "Priority": [
        "u=1, i"
      "X-Request-Id": [
        "5ef6f82a19bb0752aa63507c016f503c"
      "Sec-Ch-Ua": [
        "\"Chromium\";v=\"140\", \"Not=A?Brand\";v=\"24\", \"Google Chrome\";v=\"140\""
      "Dnt": [
        "1"
      "Accept": [
        "image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"
      "Accept-Language": [
        "de,en;q=0.9"
      "Referer": [
        "https://cloud..../uptime/"
      "X-Forwarded-Scheme": [
        "https"
      "Sec-Ch-Ua-Platform": [
        "\"macOS\""
      "Sec-Fetch-Dest": [
        "image"
      "Sec-Ch-Ua-Mobile": [
        "?0"
      "Accept-Encoding": [
        "gzip, deflate, br, zstd"
      "X-Forwarded-Host": [
        "cloud...."
      "Sec-Fetch-Site": [
        "same-origin"
      "X-Forwarded-For": [
        "62...."
      "X-Forwarded-Port": [
        "443"
      "User-Agent": [
        "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36"
  "bytes_read": 0,
  "user_id": "",
  "duration": 0.000004567,
  "size": 0,
  "status": 0,
  "resp_headers": {
    "Server": [
      "Caddy"
library/caddy:latest
Docker / Kubernetes environment
        log default {
                level DEBUG
                        roll_size 10mb
                        roll_keep 20
                        roll_keep_for 720h
http://* {
                output file /var/log/caddy/vhost.access.log
        reverse_proxy /uptime http://uptime-kuma:3001 {
        # pgadmin
        handle /abc/* {
                header X-Forwarded-Proto http
                uri strip_prefix /abc
                reverse_proxy http://postgres-admin:80
        # uptime
        #       handle /uptime/* {
        #header X-Forwarded-Proto http
        #uri strip_prefix /uptime
        #                reverse_proxy http://uptime-kuma:3001
