I have a reverse proxy setup where a bare https://example.com
is protected by Authelia, and https://example.com/whatever_here
is not. The idea is to limit the people who can create a shared file (the GUI is at https://example.com
), but freely allow for the files to be retrieved by anyone when they know the URI ( https://example.com/some_key_here
https://example.com {
@add_file {
path /
@share_file {
path /*
reverse_proxy @share psitransfer:3000
import authenticate-with-authelia
reverse_proxy @share_file psitransfer:3000
The idea is to first match the freely available URI, and then if there is no match, load the Authelia configuration, and then allow for the GUI in case the authentication is OK.
Now I would like to extend this configuration by having https://example.com/admin
protected by Authelia, via a new named matcher:
@admin {
path /admin
My problem: I do not know how to mix this with the setup above. Either
- I match
@admin
first (but I would need toimport authenticate-with-authelia
and have everything authenticated (including what I do not want) → - or I first match
@share_file
and it will also match/admin
Ideally, I would look for conditional blocks such as
if @admin then { import authenticate-with-authelia; reverse_proxy ...}
but it looks like the matcher always comes after the command (or rather, in addition to the command).
How can I approach this?
