2.11
Docker
docker-compose up -d
version: "3"
reverse-proxy:
image: caddy
container_name: reverse-proxy
- /root/config/caddy/Caddyfile:/etc/caddy/Caddyfile
- /root/config/caddy:/data
- 443:443
home-website:
image: caddy
container_name: home-website
- /caddy/home:/usr/share/caddy
assets-website:
image: caddy
:443 {
tls /data/ssl/example.com.pem /data/ssl/example.com.key
handle_errors {
root * /data/error-pages
rewrite * /{http.error.status_code}.html
home.example.com {
reverse_proxy localhost:4000
assets.example.com {
reverse_proxy localhost:8050
I have a blank page when there’s an error even though there’s an 404.html file at /data/error-pages/404.html
{"level":"info","ts":1594127779.476189,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1594127779.4783037,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
2020/07/07 13:16:19 [WARNING] Stapling OCSP: no OCSP stapling for [cloudflare origin certificate *.example.com example.com]: no URL to issuing certificate
{"level":"info","ts":1594127779.4790118,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"assets.example.com","server_name":"srv0"}
{"level":"info","ts":1594127779.4790308,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"home.example.com","server_name":"srv0"}
{"level":"info","ts":1594127779.4790447,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1594127779.4797516,"logger":"tls","msg":"cleaned up storage units"}
2020/07/07 13:16:19 [INFO][cache:0xc0007b4000] Started certificate maintenance routine
{"level":"info","ts":1594127779.4875376,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1594127779.4875915,"msg":"serving initial configuration"}
I tried to move handle_errors to :80 and to inside home.example.com, assets.example.com and *.example.com with no luck.
