I’m not sure what you mean by {slug}.
Do you mean you want basicauth to apply for any request to a file that exists on disk, but not for any request to files that don’t exist?
Right now with not path /*, this means “not (every possible path)”, which is basically the same as saying “never”.
Maybe you wanted something like this:
@auth file
basicauth @auth {
amzv JDJ5JDEyJFYvVXVyWXFIemNsUjlwMUlZdGJ4di5hTkxSUDZHd2JTekRVdUgvR0dKdkN0RGdDSXFqUmhlIA==
This uses the file matcher which has the default behaviour of checking if the current request path is a file that exists on disk (similar to try_files {path} except it doesn’t do a rewrite, it’s just the matcher part).
Also, I would organize your Caddyfile like this, for clarity (also added root because it seems you left it to be implicit, better to specify it for clarity):
localhost {
tls /etc/ssl/certs/server.crt /etc/ssl/certs/server.key
root * .
try_files {path} /index.html
@auth file
basicauth @auth {
This places each directive according in the order the Caddyfile adapter would sort them, according to the pre-defined order here:
Having said that, you’ll notice that try_files is ordered higher than basicauth. This will cause a problem, because try_files does a rewrite of the request path, but the basicauth matcher probably needs to work on the original request path to work correctly (if I’m understanding your goal, I mean). So to solve this, we would use route to force those to run in a particular order instead of their default order:
localhost {
root * .
route {
@auth file
basicauth @auth {
