Hi, I’m using centos 8.1, installed the caddy2 using dnf, how do I update to final release?
When I delete the caddy file, and I do a dnf install, it will install the beta version again.
Unfortunately the Caddy COPR repo hasn’t been updated yet. It will be soon!
See here: Builds for @caddy/caddy
/cc @carlwgeorge
The COPR was updated to the 2.0.0 version later that day.
https://copr.fedorainfracloud.org/coprs/g/caddy/caddy/build/1369235/
Thank you for your work on that, Carl!
