And again I’m trying to find the best way for simple rewriting path, but can’t understand a synthax of the Caddyfile.
With nginx I used this type construction: try_files /first/$1 /second/$1 =404;
In Caddy I try this:
try_files {path} {
path_regexp first ^/first/(.*)
rewrite /second/{re.first.1}
But this doesn’t work.
An in my case I have a troubled circumstances — this block located inside handle_path.
Could you advise where I can look for answer?
I think you’re just looking to do this:
try_files /first/{path} /second/{path}
I don’t know why, but in my case it doesn’t work:
host {
handle_path /first/* {
root * /first
try_files /first/{path} /{path}
root * /all
At the end I’ve solved it with change the root folder. It’s not the answer on my question, but it works for my case. Hope someone find it useful
host {
root * /first
@try_files {
not {
file {
try_files {path}
handle @try_files {
root * /all
You can write it more simply like this:
example.com {
root * /first
@try_files not file {path}
handle @try_files {
root * /all
system
(system)
Closed
6
