We are building a reverse proxy for http://crates.io
. When a user visits a url like http://crates.io/api/v1/crates/matches/0.1.6/download
, it will be 302
redirected to http://static.crates.io/...
. Now I was wondering is there any way to substitute all statis.crates.io
in location
header of the response with our-static-mirror.domain.com
, so that we can also reverse proxy static.crates.io
When this Pull Request is merged, you should be able to.
You’ll then be able to put header_downstream Location static.crates.io our-static-mirror.domain.com
within the proxy directive to fix the redirects.
Pretty slick PR, imo. With that and http.filter
, I expect you should be able to reverse proxy literally anything, at any arbitrary hostname and base path.
