I am trying to set up cgit using Caddy.
This is an example of how I got it running with my nginx test machine:
server {
listen 8081;
server_name git.cgittest;
root /usr/local/www/cgittest;
index cgit.cgi;
try_files $uri @cgit;
location @cgit {
index cgit.cgi;
fastcgi_param PATH_INFO $uri;
fastcgi_param SCRIPT_FILENAME $document_root/cgit.cgi;
fastcgi_param CGIT_CONFIG $document_root/cgitrc;
fastcgi_param HTTP_HOST $server_name;
fastcgi_param QUERY_STRING $args;
fastcgi_pass unix:/var/run/fcgiwrap/fcgiwrap.sock;
include fastcgi_params;
I am not sure how I am supposed to approach this with Caddy, since there is a cgi plugin I would not have to use fcgiwrap? Would it better to use it anyway? In both cases I do not know how to set this up, given that I am new to the operation of web servers in general.
I am using Caddy 0.10.0, and my OS is FreeBSD 11.0.
I would be glad if someone could show me an example of how to get it running , also happy for every other piece of information.
