caddy version
I don’t know. This my first time trying to use Caddy.
This is what I have tried:
modified the “/etc/caddy/Caddyfile” as below
# this machine's public IP, then replace the line below with your # domain name. ijs.moe # Set this path to your site's directory. root * /app/ijs # Enable the static file server. file_server www.ijs.moe { reverse_proxy 127.0.0.1:8001 } api.ijs.moe { reverse_proxy 127.0.0.1:8002 }
cat /etc/redhat-release
CentOS Linux release 8.3.2011
docker version
Client: Docker Engine - Community
Version: 20.10.5
API version: 1.41
Go version: go1.13.15
docker-compose version
docker-compose version 1.28.6, build 5db8d86f
docker-py version: 4.4.4
CPython version: 3.7.10
OpenSSL version: OpenSSL 1.1.0l 10 Sep 2019
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
8679a3692684 ijs:latest “/app/entrypoints/ap…” 11 minutes ago Up 11 minutes (healthy) 8001/tcp, 0.0.0.0:8002->8002/tcp ijs_api
aea9a426f613 ijs:latest “/app/entrypoints/cr…” 11 minutes ago Up 11 minutes 8001-8002/tcp ijs_cron
420d1a35e347 ijs:latest “/app/entrypoints/de…” 11 minutes ago Up 11 minutes (healthy) 0.0.0.0:8001->8001/tcp, 8002/tcp ijs_admin
9e8ae0ba604a postgres:12.5 “docker-entrypoint.s…” 11 minutes ago Up 11 minutes 5432/tcp ijs_db
paste command here
paste full file contents here
# domain name.
ijs.moe
root * /app/ijs
www.ijs.moe {
api.ijs.moe {
# php_fastcgi localhost:9000
I am trying to use Caddy, when when I / others visit my site. it will serve as ijs.moe without needing the port 8001. and would like to have https for my site.
[root@ijs ]# sudo systemctl status caddy
● caddy.service - Caddy
Loaded: loaded (/usr/lib/systemd/system/caddy.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2021-04-03 17:07:05 UTC; 14s ago
Docs: Welcome — Caddy Documentation
Process: 140107 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 140107 (code=exited, status=1/FAILURE)Apr 03 17:07:05 ijs caddy[140107]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
Apr 03 17:07:05 ijs caddy[140107]: HOME=/var/lib/caddy
Apr 03 17:07:05 ijs caddy[140107]: LOGNAME=caddy
Apr 03 17:07:05 ijs caddy[140107]: USER=caddy
Apr 03 17:07:05 ijs caddy[140107]: INVOCATION_ID=712b443ee5ab413e8b0a303c13a6be6c
Apr 03 17:07:05 ijs caddy[140107]: JOURNAL_STREAM=9:173097
Apr 03 17:07:05 ijs caddy[140107]: {“level”:“info”,“ts”:1617469625.2124047,“msg”:“using provided configuration”,“config_file”:"/etc/caddy/Caddyfile",“config_adapter”:""}
Apr 03 17:07:05 ijs caddy[140107]: run: adapting config using caddyfile: /etc/caddy/Caddyfile:18: unrecognized directive: www.ijs.moe
Apr 03 17:07:05 ijs systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Apr 03 17:07:05 ijs systemd[1]: caddy.service: Failed with result ‘exit-code’.
[root@ijs ]# vim /etc/caddy/Caddyfile
I followed the guide given by the default Caddy
Your web server is working. Now make it work for you.
Caddy is ready to serve your site over HTTPS:
Point your domain's A/AAAA DNS records at this machine. Upload your site's files to /var/www/html. Edit your Caddyfile at /etc/caddy/Caddyfile: Replace :80 with your domain name Change the site root to /var/www/html Reload the configuration: systemctl reload caddy Visit your site!
www.ijs.moe:8001
www.ijs.moe:80
