How to set self ssl inside tls config in docker #5651
i want to use this s
sample.com {
        root * /workspace/public
        php_fastcgi app:9000 {
            root /workspace/public/
            protocols tls1.2 tls1.3
            ciphers TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
        @cachedFiles {
            path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.webp *.svg *.woff *.woff2
        header @cachedFiles Cache-Control "public, max-age=31536000, must-revalidate"
        # HSTS (63072000 seconds)
        header / Strict-Transport-Security "max-age=63072000"
also i want to set my cert in tls like tls /etc/ssl/mycert-chain.pem /etc/ssl/mykey.pem but not work.please show me how to config ssl in tls
What do you mean it doesn’t work? What’s your evidence that it doesn’t work? What does it show in your logs? Please be more specific.
Also, there’s no need to specify protocols or ciphers. Caddy uses secure defaults and changing them can only lower your security.
I need to use my own ssl
The format for your own SSL would be
tls /usr/local/etc/pki/tls/certs/fullchain.pem /usr/local/etc/pki/tls/private/privkey.pem
The paths should be the paths to your cert and key.
Where should I put a path in the cert disk and mount it to the docker volume?
I don’t use docker. I just know the above format works if the files are present.
How you mount the files into your Docker container is up to you. But you can either copy it into your container at build time with a Dockerfile, or use a bind mount to put it somewhere like /certs, etc.
Either way, the syntax is tls <cert.pem> <key.pem> as per tls (Caddyfile directive) — Caddy Documentation
