2.3.0-alpine on docker
in docker on a digital-ocean docker droplet
Dockerfile:
# https://hub.docker.com/_/caddy
FROM caddy/caddy:2.3.0-alpine
COPY /html /html
version: '3.7'
db:
# specify container name to make it easier to run commands
container_name: ae_db
restart: always
image: db
build:
context: ./db
env_file:
- ./.env
- network
expose:
- '5432'
# make the Postgres database accessible from outside the Docker container on port 5432
- '5432:5432'
- db_data:/var/lib/postgresql/data
- sik_data:/sik_data
graphql:
container_name: ae_graphql
build:
context: ./graphql
- network
expose:
- '5000'
- '5000:5000'
depends_on:
- db
env_file:
- ./.env
command:
'--connection',
'${DATABASE_URL}',
'--schema',
'ae',
'--append-plugins',
'postgraphile-plugin-connection-filter,@graphile-contrib/pg-order-by-related',
'--jwt-token-identifier',
'auth.jwt_token',
'--default-role',
'anon',
'--jwt-secret',
'${JWT_SECRET}',
'--body-size-limit',
'300kb',
'--cors',
'--disable-query-log',
'--enable-query-batching',
'--retry-on-init-fail',
json:
container_name: ae_json
restart: always
build:
context: ./json
- network
expose:
- '4000'
- '4000:4000'
depends_on:
- db
env_file:
- ./.env
build:
context: ./caddy
container_name: ae_caddy
- network
depends_on:
- graphql
- json
restart: always
# original image downgrades user but that seems not to work
# see: https://caddy.community/t/basic-docker-compose-setup-failing/6892/7?u=alexander_gabriel
user: root
- '80:80'
- '443:443'
env_file:
- ./.env
- caddy_certs:/root/.local/share/caddy
- caddy_config:/root/.config/caddy
db_data:
sik_data:
caddy_certs:
caddy_config:
network:
I am using this Caddyfile:
artdaten.ch, www.artdaten.ch {
# how to set headers for gatsby?
# https://caddyserver.com/docs/caddyfile/directives/header
root * /html
encode zstd gzip
api.artdaten.ch {
reverse_proxy /graphql* {
to ae_graphql:5000
header_down Access-Control-Allow-Origin *
reverse_proxy /graphiql* {
to ae_graphql:5000
reverse_proxy /json-api-test {
to ae_json:4000
reverse_proxy /artendb/* {
to ae_json:4000
reverse_proxy /evab* {
to ae_json:4000
reverse_proxy /alt* {
to ae_json:4000
The build copies the static files created by gatsby from the public folder into the correct html folder:
gatsby build && rimraf backend/caddy/html && copyfiles -u 1 \"public/**/*\" backend/caddy/html
But then running npx check-gatsby-caching https://artdaten.ch
to check the headers gives:
HTML
https://artdaten.ch
- Expected
+ Received
Object {
- "max-age": 0,
- "must-revalidate": true,
- "public": true,
+ "null": "No cache-control header set",
app-data.json
https://artdaten.ch/page-data/app-data.json
- Expected
+ Received
Object {
- "max-age": 0,
- "public": true,
Page Data
https://artdaten.ch/page-data\index\page-data.json
- Expected
+ Received
Object {
- "max-age": 0,
- "public": true,
JavaScript and CSS
https://artdaten.ch/webpack-runtime-5634eb39a001e537d772.js
- Expected
+ Received
Object {
- "immutable": true,
- "max-age": 31536000,
- "public": true,
So my question is:
How can I for example set headers for https://artdaten.ch/page-data\index\page-data.json
to be:
"max-age": 0
"public": true
I checked header (Caddyfile directive) — Caddy Documentation and tried a few variants but I do not seem to understand it.
