2.2.1
I am using a docker image caddy/caddy:2.2.1-alpine
This is my docker version 19.03.13-ce
docker run -p 80:80 -p 443:443 -v "${PWD}":/srv/ -v "${PWD}"/Caddyfile:/etc/caddy/Caddyfile -v "${PWD}"/certs:/data -v "${pwd}"/config:/config caddy/caddy:2.2.1-alpine
I am using docker container
on_demand_tls {
ask https://mysaas.com/api/v1/allowed-domains
interval 2m
burst 5
:443 {
output stdout
on_demand
reverse_proxy https://mysaas.com {
header_up X-Forwarded-For {http.request.remote}
header_up X-Real-IP {http.reverse-proxy.upstream.address}
header_up X-Forwarded-Proto {http.request.scheme}
header_up X-Forwarded-Host {http.request.host}
The main issue I am having is that the external application does a redirect and my custom domain url changes to the redirected url. I want to user to remain the address they typed in. welcome.cupcakes.com/videos/1
for example as client
i go to welcome.cupcakes.com/videos/1
i want to serve this the content from my saas application https://www.welcome.cupcakes.saas.com/videos/{id}
I tried different Caddy file configuration to see what works as shown above.
matt
(Matt Holt)
May 30, 2021, 4:51am
#2
Hmm, where did you get these from? Did you verify that these lines are actually necessary?
What is the output of curl -v
Hey Matt,
I dont think they are necessary to be honest and haven’t noticed any difference if leave them out.
This is the curl output after curl -v (i replaced the urls and ip address)
curl -v https://videos.cupcakes.com/g/sqI0tKiVvHT
* Trying 54.252.210.254...
* TCP_NODELAY set
* Connected to videos.cupcakes.com (54.252.210.254) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES256-GCM-SHA384
* subject: CN=videos.cupcakes.com
* start date: May 25 03:50:33 2021 GMT
* expire date: Aug 23 03:50:33 2021 GMT
* subjectAltName: host "videos.cupcakes.com" matched cert's "videos.cupcakes.com"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x7fde6400c400)
> GET /g/sqI0tKiVvHT HTTP/2
> Host: videos.cupcakes.com
> User-Agent: curl/7.64.1
< HTTP/2 302
< cache-control: no-cache, private
< content-type: text/html; charset=UTF-8
< date: Sun, 30 May 2021 05:13:36 GMT
< location: https://video.test.saas.co/g/sqI0tKiVvHT
< server: Caddy
< server: nginx/1.15.8
< set-cookie: laravel_session=4fbp2M3TduOdU5t9HHWRaTDGNrD0aVP7A3uC7a9u; expires=Tue, 01-Jun-2021 17:13:36 GMT; Max-Age=216000; path=/; httponly; samesite=lax
< x-frame-options: SAMEORIGIN
< x-robots-tag: none
< x-xss-protection: 1; mode=block
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8" />
<meta name="robots" content="noindex,nofollow" />
<style> body { background-color: #fff; color: #222; font: 16px/1.5 -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, "Helvetica Neue", Arial, sans-serif; margin: 0; }
.container { margin: 30px; max-width: 600px; }
h1 { color: #dc3545; font-size: 24px; }</style>
</head>
<body>
<div class="container">
<h1>Whoops, looks like something went wrong.</h1>
</div>
</body>
* Connection #0 to host videos.cupcakes.com left intact
That’s not the official docker image, use caddy
instead. The caddy/caddy
image is our CI pipeline target instead. See on Docker Hub
Also, please upgrade! v2.2.1 is pretty old now. v2.4.1 came out last week.
As Matt said, you don’t need these lines. Caddy will set the appropriate headers correctly, automatically.
Try to avoid copy-pasting bits of config you don’t understand.
The redirect must be coming from your nginx server, or from your application. This isn’t a problem with Caddy. Make sure they’re configured to not trigger redirects, or to correctly handle/detect the X-Forwarded-Host
header to make any redirects retain the original domain.
It looks like you’re serving a Laravel app from what I can tell (the clue is the set-cookie
header). I would recommend to use Caddy instead of Nginx to serve your app. Caddy can easily serve Laravel apps with the php_fastcgi
directive, and you would avoid the indirection of having to proxy through another server for your custom domains. Just let Caddy handle it all.
system
(system)
closed
June 29, 2021, 1:13am
#5
