Hello,
I’m try using caddy to serve my reatjs single page app which use react-router with browerHistory.
I want caddy handle static files first, then if not found rewrite to /index.html
Could caddy handle it?
Thanks
Hello,
Thanks
Have a look at the Caddy rewrite docs - you’re after the block version, specifically the to
subdirective.
Thanks. It’s helpful.
0.0.0.0:80
root /var/www/html
log stdout
errors stdout
rewrite / {
to {path} /
I have done it with this configure.
