): 2.4.5 alpine
2. How I run Caddy: Docker
a. System environment: Docker linux
c. Service/unit/compose file: docker docker compose
app.localhost {
file_server browse
# reverse_proxy 172.172.0.15:8888
localhost {
reverse_proxy 172.172.0.15:8181 {
file_server browse works fine, but the reverse proxy is not working i think its because my backend server is Golang Fiber which does not support http2 . How i can tell to reverse proxy using http1 ?
{“level”:“error”,“ts”:1635821206.3486726,“logger”:“http.log.error”,“msg”:“dial tcp 172.172.0.15:8181: connect: connection refused”,“request”:{“remote_addr”:“172.172.0.1:44574”,“proto”:“HTTP/2.0”,“method”:“OPTIONS”,“host”:“localhost”,“uri”:"/core/api/v1/open/login",“headers”:{“Sec-Fetch-Site”:[“cross-site”],“Accept-Language”:[“en-US,en;q=0.5”],“Accept-Encoding”:[“gzip, deflate, br”],“Sec-Fetch-Mode”:[“cors”],“Te”:[“trailers”],“User-Agent”:[“Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:93.0) Gecko/20100101 Firefox/93.0”],“Access-Control-Request-Headers”:[“content-type”],“Dnt”:[“1”],“Accept”:["/"],“Sec-Gpc”:[“1”],“Sec-Fetch-Dest”:[“empty”],“Access-Control-Request-Method”:[“POST”],“Referer”:[“http://localhost:9000/"],“Origin”:[“http://localhost:9000”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“proto_mutual”:true,“server_name”:“localhost”}},“duration”:0.000403205,“status”:502,“err_id”:“cr0wg9kk3”,“err_trace”:"reverseproxy.statusError (reverseproxy.go:858)”}
