bjdaijun
(Bjdaijun)
July 28, 2021, 2:40pm
#1
caddy 2
systemctl start caddy
ubuntu 18.04
Paste command here.
:45000 {
handle /* {
root * /home/mywork/CgsBim
handle /api/* {
reverse_proxy http://127.0.0.1:2020
handle_path /bimface/api/* {
reverse_proxy https://api.bimface.com {
header_up X-Forwarded-Proto https
When I POST http://39.99.156.137:45000/bimface/api/oauth2/token in my code, It returned an 302 to an http url. But the real api address is https://api.bimface.com , and I dont know why it redirect to an http address that seems not exists.
So I add "header_up X-Forwarded-Proto https " , to reverse_proxy, but still got 302 result.
And I tried the https address with postman, This address https://api.bimface.com works fine.
You need to make sure that the Host
header is correctly set. By default, Caddy passes through the Host
header from the original request.
You can solve this by using a placeholder which takes the value of the currently selected upstream:
bjdaijun:
handle /* {
You can simplify this by removing the matcher altogether:
The difference is that with the matcher specified, Caddy will have to make a comparison against the request path on each request, which will always match (because the path always starts with /
). Omitting it avoids that redundant check.
bjdaijun
(Bjdaijun)
July 29, 2021, 2:01am
#3
This Solved perfectly.
But handle / not work , It just result to a blank page. Not my index.html, and can’t find the real reason.
I will retry this later.
Thanks for your help.
Don’t use /
, just remove the matcher altogether. Use handle {
Using /
will only match requests to /
exactly. Omitting it will match all requests.
bjdaijun
(Bjdaijun)
July 29, 2021, 2:36am
#5
francislavoie:
Don’t use /
Using /
Yes, This config works well.
Thanks agian.
system
(system)
closed
August 27, 2021, 2:40pm
#6
