I do not understand how caddy works, but I need to fix this error quickly, can you help me in more detail?
I use redir api.domain.local{uri}, when I access admin.domain.local will redirect directly to api.domain.local this is incorrect, I revised theredir /api api.domain.local{uri}but it does not work, it does not seem to recognize the request containing /api, I tried using the if {path} test / api condition to redirect to https://api.domain.local{uri}, it navigated to api.domain.local, but api doesn’t receive this request, OPTIONS https://api.domain.local/api/auth/login net::ERR_CERT_AUTHORITY_INVALID, I’m quite confused about this, I’m still trying to fix it.
So yeah, redir /api api.domain.local{uri} wouldn’t work if you want to be redirected from, for example, admin.domain.local/api/foo. Only the literal, exact path /api will be redirected.
If you tried something like:
redir {
if {path} starts_with /api
to api.domain.local{uri}
That should work.
As for…
Sounds like whatever program is trying to access it doesn’t trust the SSL certificate that the api.domain.local site is offering.
redir {
/ https://api.domain.local{uri}
It worked, but now I have a problem with Access-Control-Allow-Origin,
Access to fetch at 'https://api.domain.local/api/auth/login' (redirected from 'https://admin.domain.local/api/auth/login') from origin 'https://admin.domain.local' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
My server has set Access-Control-Allow-Origin to accept all requests, but it doesn’t work, I think the problem is when using redirect.
What do I need to do to resolve this issue, can I use reverse proxy instead of redir?
I don’t know what the client is, but the answer is in the error it’s produced for you:
Disable the CORS checking in your client, or add a CORS header to your site.
Using a reverse proxy might be feasible, but might probably also run into the CORS issue. You’re hosting both sites on the same Caddy instance, right? In which case, whether you reverse proxy or not is orthogonal to the CORS issue.
api.domain.local:443, admin.domain.local:443 {
# config here
#You need to copy the site config into a separate section and change the root for the different website.
Can you for example help me, I can’t find an example like this.
