I want to reuse
@nonLocal {
not remote_ip 192.168.0.0/16 172.16.0.0/12 10.0.0.0/8 127.0.0.1/32
between my site blocks, but caddy
tells me that
cannot define a matcher outside of a site bloc
So what is the recommended way to reuse matches?
I also initially wanted to define
@local {
and then define
@nonLocal {
not @local
but this resulted in parser errors.
Snippets:
This is actually a work in progress, but it’s very tricky to get right.
system
(system)
closed
#3
